My car is missing like a bastrd whenever I dip into the throttle hard. If I nurse it or shift very smoothly, it's ok and a stab from half-throttle yeilds plenty of performance and no misfires.
But stabs from a closed throttle (while at speed) yeilds bucking, then it's fine until I shift and stab the throttle hard again. The car tends to bog heavily if I shift quickly before 5500 RPM.
At idle, when I twist the throttle hard and fast for a split second, the car will miss so bad it threatens to stall (which explains why I've been stalling so much more... I have to slip the clutch a little more than usual). The car bogs heavily on hard launches if I do not drop the clutch at anything above 2500 RPM and do not smooth out my throttle control.
The car runs fine on the highway, except for the triple-buck I get when I stab the throttle. The car is NOT backfiring at all, but I did manage to get a small backfire when I was playing under the hood with the throttle. There is a loud, hollow CLACK in the intake if I twist the butterfly fast.... and then it threatens to stall for a split second, then will continue on up into the revs like nothing happened.
If I stay at half throttle (in any gear, at any RPM), the car will surge in power ever so slightly, but I can feel it. I do know my power steering pump has been acting up, but I'm not sure if this symptom is related to the misfires or my PSP is playing games with me.
Also, the lights dim every now and then, especially when the A/C compressor kicks on, I up the fan speed quickly, or I'm using more than one window button at a time. I have not full-fielded my alternator yet, so I don't know it's out put (anyone know what to jump on this particular model and what the specs should be? Yeah. I'll do a search). The only reason I include this symptom is in case any of you think it could be ignition related?
And lastly, the car starts a little hard every morning... like it's going to stall out. It then surges to 1500 RPM when it's done couging like a 50-year-old-smoker and settles to 900-1000 RPM idle. My car hasn't been run for the past 3 days, so when I started it up this morning, the car sputtered out blue smoke and sat in a lumpy, threatening-to-stall, noisy, 300-400 RPM idle until I hit the gas and it surged and it leved out. For the rest of the day... no more blue smoke from burnt oil, but I can smell something abnormal when it misfires and I get out of the car.
I haven't run a cylinder balance test yet, but does anyone agree that's where I should start? The CE light is not illuminated, and I have seen it work (I pulled the MAF), but I will run codes and post anyway.
THE SHORT VERSION:
So any suggestions or ideas? The car misses, but does not backfire. On a regular basis, there is no smoke. Starts hard. Idles fine afterward. Seems to be no loss in power (except below 4000 RPM from a standstill and the bucking thing).
Thanks in advance.
THE SHORT VERSION:
Thanks in advance.
