Broken Y-Pipe to Manifold Bolts?
Zap
West Bend, Wisconsin
I was curious if anyone can offer any suggestions for fixing the rusty Y-pipe to manifold bolts when they break. I have been tracing an exhaust problem in the '91 and all four bolts broke on me (which I somewhat expected). Is it possible to replace them yourself, or what would a shop charge to change them out?
I think I found the problem (a rattling cat... yikes!) so I wanted to pull the Y off to check if it was the problem.
Also, the y to catback was repaired at some point and there are two nuts on the end of the bolt that I simply cannot get to move. Any suggestions on removing the spring bolts when there are two nuts on the end? The y-pipe is almost off...
I had my manifolds off and in a vise and still broke two studs off. One came out and I left the other. Took both manifolds to the machine shop and they removed the one, drilled and tapped the two broken ones for $30.
Otherwise somehow you are going to have to drill them out and either preserve the threads or go bigger and use bolts that go all the way through.
DVJ38
Hartford, CT and Worc, MA
I just replaced my rodbearings and the same thing happened to me. I tried dilling out the bolts and retapping them, but it took forever and was a ****** job. So I ended up finding these awesome products for this exact purpose. They're called Clamp-a-Stud. Autozone, Checker, Advance Auto Parts don't have this product. I got mine from Thomas Auto Parts in Massachusetts. I can give you his number he would be glad to help you out. There are 2 different sizes, get the bigger one. They work great. I drove to Arizona and it's working great for holding the Ypipe on. They cost 20 each, but they work. You just need to drill a little hole (half inch deep) into the stripped bolt.
PM me if you're interested, or call a bunch of local shops, they might have them. :thumb:
