broken subframe
NJSHO
Clean Your Shorts!
NJ
Yes you can replace the subframe. Check a junkyard. Do you have pics?
93rev2sev
Hockeytown
Subframe
The correct name is engine cradle or subframe...some call it a toilet seat---where all the s--t goes. Time to let your fingers do the walking...The subframe for the MTX 3.0 is different than the Automatic...make sure you specify the correct one when calling around.
Now is a good time to paint the junkyard subframe...I was in a hurry and regret not doing it.
lazy-wes
94SHO white atx
Flat Rock, MI
Right front cradle
Hi, I have a 94 SHO 3.2 and my front right cradle has broken also. Is this an easy fix, or do I have to remove everything under the hood? I am going to completly restore this car and need help learning the car. I have a atx, Looking forward to making it one Fast car. Please give advise, Thanks to all.....
