broken sping
shonutt
Yeah I Got Rice
Saginaw MICHIGAN
was driving down the road when i heard a loud bang ..pulled over part of my spring from the passanger front was lieing on the ground :oogle: yes they are stockers... is it safe to drive with a a busted spring ..is it dangerious :shrug: :cry: :cry: :cry: what could cause this ...bad struts and strut berings :confused:
NJSHO
Clean Your Shorts!
NJ
This is a know failure on some gen 2 shos. Ford has a recall that just involves putting a housing around the spring to prevent it from causing other damage (instead of just replacing the spring.) I wouldn’t drive on it if I were you.
oh_SHO
Ohio
Both of the front springs on my 95 broke so it is not uncommon.
S
shoebilly
Guest
A busted spring will cut out a tire sidewall. This is the only reason there is a recall.
SASHO91
Zoom Zoom
San Antonio,TX
"This is the only reason there is a recall."
well and the fact that the spring BROKE....... :doh:
SHOtimer
#2910
Santa Clarita, Ca
This has got to be an east coast (read: rust) thing...my '95 had original great springs at 160k, and I have never seen or heard of a Taurus on this coast breaking a spring. I sure feel bad for the cars that have to go through that crap.
Doug
SASHO91
Zoom Zoom
San Antonio,TX
really... !!
mine, AFAIK, are stock, and still have great height to them, and still very "firm"... compared to other shos that have worn springs that i have rode in....
S
shoebilly
Guest
When the law suits become a burden, only then is there a recall. Just ask the V8cam guys. Its economics.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Doug
I have seen several broken Taurus/SHO springs. Rust does not seem to be a factor as a couple of them had the breaks in a clean section of the spring. Likewise, I have seen many springs in severe degrees of rust that worked fine. A little weak maybe, but still plenty springie with no breakie.
Perry
