RJ-92
Well for the seccond time I have a broken front MM bolt. I was driving home the other day and I knew right away what it was as soon as I started it and let the clutch out in gear... right front ****, push in clutch... "WHAM" The front lower of the two bolts and the pressed in nut are gone. And BTW when I rebuilt the mount I tacked on the bolts to the mount so they wouldn't disappear.
The only thing that I can see casusing this issue is ther clutch chatter. Normally its not too bad, but sometimes in reverse it can jounce tha tmotor around pretty good.
Any thoughts on why this is happening and what can be done to prevent it would be appreciated.
