broke valve cover bolt off
BenSwanson
Nashville, TN
i was feeling really proud of myself as i finished my valve adjustment at 0130 this morning
then God decided to humble me a bit
i broke off THE LAST bolt i was putting in on the back valve cover (one of the small bolts at the side)
it didnt seem as though i was torqueing down on it to hard, must of started it in wrong thread or something, but the head is off and the rest is down in there
i really dont know how to handle this situation as i have never had this happen. Im guessing drill it out and rethread it, any other suggestions?
BenSwanson
Nashville, TN
uhh...i just searched and found about 10 threads on this topic. so if i tried to just punch the broke piece out will i ruin the threads. what about with that sears tool? is there a way to do it w/o ruining the threads?
bybyc5
tulsa,oklahoma
if the bolt is above the head you could use a pair of vise grips and back it out, if it broke off below you could use a small drill bit and a screw extractor.
BenSwanson
Nashville, TN
the bolt is buried down in there (not sticking out at all) if i use the drill bit to get it out, will it ruin the threads?
anyone got an extra valve cover bolt, one of the small ones at the side?
MOSHO92
Modesto, CA / San Jose, CA
Wow. Im sorry, the exact same thing happened to me when i did the job. Same crappy side bolts. I ended up drilling out the entire thing after breaking two easy-outs in it. (the easy-out actually was stuck in the drilled hole, then i had to re-drill through the easy out!!) Finally got through and used a helicoil. Works perfect!
