broke/bent something - FR wheelwell
red89SHO24v
Newport, RI
i was driving rather fast over the crest of a hill, and the front of my car came off the road slightly. when the tires made contact again, i noticed the car handling badly, noise from the FR wheelwell, and also i had no brakes to speak of - the pedal was easily mashed to the floor. upon further inspection, i noticed the FR wheel is at a 5-10 degree angle such that the top of the wheel sticks out more than the bottom of the wheel. not wanting to do further damage, i limped the car to a nearby parking lot and left it there. any idea what i broke? any help would be greatly appreciated. thanks
Jon Kenney's red '89 w/ 235k miles
6463734 9469 0130009D
"modified" cats, Flowmaster mufflers, Grizzly Street Clutch, Grizzly Paw throw-out bearing, 73mm MAF, solid-rod conversion, K&N filter, Eibach Springs, KYB struts, FPS adj. aluminum control arms, 17x7.5 Neeper Synchros, 235/45/ZR17 Toyo Proxes FZ4's, TQ limiters, reinforced subframe mounts, polyurethane bushings, KVR cross-drilled rotors and carbon-fibre pads, police grille, glowing Ford emblem, red interior neons, one phat stereo system
jthomas68
Area 51
It sounds like a ball joint.When was the control arm last changed?
Jeremy Thomas
Modified 91+
Pic Of The Week:
red89SHO24v
Newport, RI
clem just put a new right-front ball joint on my car when i had my clutch done this summer. i suppose it could have broken again...ive been getting a metallic ticking noise out of that wheelwell for a while now, mostly when i turn the wheel to the left considerably. thanks again for any input.
ArrestMeRedSHO
S. Windsor, CT
Kenney that car has bad karma. You have gremlins or something.
On another note I'm staying at the Litchfield Inn for my interview next week.
1993 MTX Red w/black int
ShoShop Stage 1
Yokohama Avids 215/60/R16
RStalveyARFF
too many shos
Georgetown, MA
it sounds to me like your CV joint separated. Check the hub nut and the joint to make sure everything is tight, and check the axle for play. The ticking almost is a giveaway that it is something CV related, esp when you turn the wheel.
red89SHO24v
Newport, RI
well, the ford dealer got back to me last nite - my bearing went, and it took with it my spindle, knuckle, and axle or shaft (i dont remember exactly what she said). including towing my car, parts, and labor, my bill is about $1k, which BLOWS. damn SHO, youre lucky i love you so much...
shooff
ranson wv usa
1k is crazy!! sounds like you need to become mechanically inclined. Now that you know what needs fixed it wouldnt be too hard to do yourself!! I've been through it over and over!!
red89SHO24v
Newport, RI
well, its over and done now - got it back monday
my total bill only ended up being $700, and $75 of that was towing, which i get reimbursed from my insurance company. they put in a new axle shaft, but were able to find a used knuckle, spindle, and bearing assembly, saving me some $$$.
i wish i knew how to fix more things myself, but my dad isnt into cars, so i didnt grow up with any car-knowledge or teaching. i can do small things (brakes, O2 sensors, oil changes) but anything beyond that is up to mechanics. oh well...
