bushing advice
red89SHO24v
Newport, RI
i broke one of my rear swaybar end links, and therefore need to replace it. from what im told, urethane bushings are the way to go - does anyone reccomend a specific bushing or kit? i figure i should replace both bushings (L&R) to keep everything consistent. thanks
Jon Kenney's red '89 w/ 240k miles
6463734 9469 0130009D
"modified" cats, Flowmaster mufflers, Grizzly Street Clutch, Grizzly Paw throw-out bearing, 73mm MAF, solid-rod conversion, K&N filter, Eibach Springs, KYB struts, FPS adj. aluminum control arms, 17x7.5 Neeper Synchros, 235/45/ZR17 Toyo Proxes FZ4's, TQ limiters, reinforced subframe mounts, polyurethane bushings, KVR cross-drilled rotors and carbon-fibre pads, police grille, glowing Ford emblem, red interior neons, one phat stereo system
red89SHO24v
Newport, RI
fred -
did the bushings come with the hardware (including the post) or if not, where can i get what i need? the post broke at the point of intersection with the swaybar end. thanks
