are 225/60/16 snowtires too big??
red89SHO24v
Newport, RI
all right, i think i may have just goofed ordering my snow tires - i ordered the Blizzak WS-50's in 225/60/16 to put on my slicers for the winter - are these gunna rub? im not too concerned about the width, as i run my 235/45/17's on 7.5" rims with no problems. but is the OD of the tire going to be too large for my car? any input would be greatly appreciated! thanks
Jon Kenney's red '89 w/ 235k miles
6463734 9469 0130009D
"modified" cats, Flowmaster mufflers, Grizzly Street Clutch, Grizzly Paw throw-out bearing, 73mm MAF, solid-rod conversion, K&N filter, Eibach Springs, KYB struts, FPS adj. aluminum control arms, 17x7.5 Neeper Synchros, 235/45/ZR17 Toyo Proxes FZ4's, TQ limiters, reinforced subframe mounts, polyurethane bushings, KVR cross-drilled rotors and carbon-fibre pads, police grille, glowing Ford emblem, red interior neons, one phat stereo system
jthomas68
Area 51
That`s what i normally run,and i`ve had no problems with Goodyears what so ever.
Jeremy Thomas
Modified 91+
Pic Of The Week:
ArrestMeRedSHO
S. Windsor, CT
You already know of my problems withthat size, I had Toyos that rubbed the coil plates when they accidentally put on that size. Just wanted to mention it here for others.
BTW is that a new pic?
1993 MTX Red w/black int
SHO Shop Y-pipe and Flex pipe
Dynomax Catback
Underdrive Pulleys
80mm MAF
LPM
"Fishtank Lights"
CincySHO Floormats
Yokohama Avids 215/60/R16
red89SHO24v
Newport, RI
flounder -
i had ordered that size tires right before i called you yesterday - i figured id ask as many people as possible. and that pic is newer - i put it up earlier this fall. BTW, i see youre still too lazy to take a pic for your sig
