brakes problem
mikestoys
ohio
i have replaced mc and caliper rotor and pads rears plus new brake liines rear and rubber hoses and the pedal will pump up but if it sits for a minute pedal goes to the floor
yamahaSHO
E85 whore
Arkansas
Sounds like there is air in the system. How well have you bled the system? Are you still getting bubbles? Did you install the calipers with the bleeder facing upward?
SHOspazz92
Banned
Triad Area, North Carolina.
This.
You need to take some time to bleed the brakes properly. I've only done this once with Kirk on my track car. It took quite a while to get it right (Part of it was the bleeders on the wilwoods being a little clogged up).
-Sam
Mike93
Go Sabres!!!
Buffalo, NY
Any fluid leaking anywhere? If not...as said above keep bleeding the brakes. Also, some more definition in your description may help us troubleshoot where your problem may be originating from.
lowc
aka vapah lock
Quincy, massachusettes
did you bench bleed the master?and bleed the lines at the master?it def sounds like air in the system
