Chesapeake
Re: Brake Problem
Dear Drivers:
Again I seek the knowledge of the forum members. Searched past posts and have an idea about the problem, but thought I'd post a detailed description (don't want to throw too many parts at the problem).
-Car is an all stock 91+. 128K miles
-Just purchased, but all brake pads looked nearly new when inspected
Problem Description;
Last knight, while driving at highway speed (65-70mph) started noticing a drag on the car. While braking slightly to get into the slow lane, I noticed the pedal response was immediate and that the car shook pretty hard. Steering wheel oscillated right to left (actually, it felt like the whole front end was bucking). Could feel increased drag and put it into 4th because in 5th it was causing the engine to lag. Pulled off the highway to inspect and found that the passenger rear brake, although it was not smoking, had that burnt brake smell -touched the Slicer rim and found it was much hotter than the driver rear. Both fronts were hot but did not smell –both felt about the same temp. Sat there for about 10 minutes wondering if I would need a tow. Decided to see if it had freed up & tried for home (only about 2 miles of back roads). Felt like she freed up, but did much downshifting and tried to stay off the brakes as much as possible.
This happened once before, momentarily, and went away. So quickly that I thought I might have imagined it.
This morning I took the car for a short ride (back roads & highway). It felt OK, pedal worked without bucking, but felt like she may still have a very slight drag holding her back.
All of your comments & past solutions will be appreciated.
Thanks in advance!
Dear Drivers:
Thanks in advance!
