Brake Upgrade
marbs
Roy/Ogden, Utah
O.K I know this is talked about ALL THE TIME. I've done a search and read literally every post dealing with this. I'm asking this because it just confused me to read all of those posts.
I have a 94' I RARELy race it. I've 1/4 miled it once, and I'm THINKING of Auoto Crossing it though. What would be the best upgrade for me to do and what parts do I need? 96' Upgrade or the Cobra Upgrade? Should I also do the 92' Upgrade? What is the true difference in stopping power? Also what's the difference in price? One last thing I need it to fit under my slicers, do they? :cool:
Sh03d
Sho Ed
Fairfax VA
96' brake upgrade will fit no probelm, cobra will need bigger wheels unless modified. 92' Rear brakes arent a bad idea for autocross, but might not be worth the money.
jedhead
westminster,ca
The only upgrade that I aware of that uses PBR calipers and still fit slicers is Baer Racing 12.5" upgrade using redrilled Corvette Rotors and modified knuckles. I agree that the 96 upgrade and good pads would be the way to go for you.
Bob
DHMag
Free At Last
InCahoots, Texas
Bob
Mustang GT and Mustang Cobra calipers are PBRs.
Cobra Caliper/11.6" rotor here, love it.
shomesomesho
G-force addict
more rubber, more HP.....
Ok, somebody correct me if I'm wrong, but the PBR GT (not Cobra) dual piston calipers/brackets will bolt up to SHO '94-'95 spindles without modification. Uses the stock SHO rotors, but hey you get dual piston, right? And it fits under slicers?
marbs
Roy/Ogden, Utah
I am a Memeber a Ford Club here locally, so I should be able to get 92 rears for pretty cheap. Somone is almost ALWAYS pating out a SHO.
I am most likely getting The Brakets(and I think the bolts) from a memeber here. Is all that I'll need is 96 Rotors and 96 pads? What is the best ones for the money?
Sh03d
Sho Ed
Fairfax VA
Anybody know? If so that would be very cool.
NWGRN94MTX
Vancouver, WA U.S.A.
Bob
Not true. SHO Parts Northwest has a SHO PBR kit that fits under Slicers.
revhardSHO
Seattle, WA
Just go with the 96+ brakes. Great stopping power + more durability + low cost. Since you have a 94 all you need are the larger caliper brackets ($100 for a both, iirc), nice set of PFC pads (AZ or parts store), and some basic 11.6" rotors ($20.00 from AZ). Install, bleed, and your all set!
Jonny Cash
Good boy
Hollywood, FL
Same setup here..
I also love it.
BTW with no mod. besides 99 knuckles, my slicers fit perfectly over my 98 cobra calipers.
No spacers, no nothing. I was told over and over again that they wouldnt fit....
Sh03d
Sho Ed
Fairfax VA
Hmm so 1999 mustang PBR two piston calipers will fit on a 94-95 SHO with 96 brake upgrade?
shomesomesho
G-force addict
jonny cash said:
Same setup here..
I also love it.
So you had to use Gen3 '99 knuckles or was that a typo?? Please clarify.
Jonny Cash
Good boy
Hollywood, FL
[/IMG]
[/IMG]
[/IMG]
The gen3 knuckles are lighter, and they add a bit more camber adjustment too.
I dont have any pics with the wheel off, but you get the point.
You gotta love that clearance
These are 98 cobra's, with hawk pads, powerslots, and steel braided brake lines.. Stops very well.
