OK, confirmed.
Sh03d said:
Let me know when its confirmed.
The Mustang GT PBR calipers (NOT Cobra)
does fit under slicers with plenty room to spare.
Basically, these are PBR GT (not cobra) dual piston aluminum calipers on stock 10.75" (10.8"?) '94-95 SHO rotors.
Requires '94-95 knuckles/spindles.
Costs:
Used GT calipers on ebay for ~$50.
'94-95 knuckles from the junkyard $60/pair.
New pads $50.
I already had '94-'95 rotors on hand from a prior swap, but you can find them new for ~$25 each on rockauto.
(Threw in some stainless steel brake lines ($90) with the money I saved.)
Informal testing using my own personal butt G-Tech feels that these stop about as well as the '96 brake upgrade (which uses a larger diameter 11.6" but 2 lb. heavier rotor and single piston cast iron caliper which don't dissipate heat as well as aluminum).
This rig definitely stops better than stock, and that's good enough for what
this '91 SHO Plus will be used for.
Not too shabby for ~$150 (w/o the SS brake lines). YMMV.
I'm sure this has been done before, but I got the idea from here:
Thunderbird Brake Upgrades. Check out the 4-piston Brembo calipers on 13" rotors -- now that is HOT.
The GT calipers have this open slot in the middle, that is not present on the Cobra calipers.
It fits under slicers!
