brake upgrade question
92sho16
b00sted
Liverpool, NY
My question is some what simple.I have a 92. Money is tight and i dont want to have to pay for alignment twice so i would do the struts and springs at the time that i would change the knuckles.Is it at all possible to put the 94 + knuckles on my car without doing the rest of the upgrade? My assumption is that its not possible but any guru's know for sure ?
Shoaz
Studly dood
Scottsdale, AZ
92sho16:
If you're asking whether the pre-94 brakes can be put on 94 knuckles, no they can't. Sorry.
92sho16
b00sted
Liverpool, NY
Thank you both for your help. Looks like ill have to do the brakes first and then next summer do struts and srpings b4 running at watkins glen.
Shoaz
Studly dood
Scottsdale, AZ
92sho16:
That's not a bad order, actually. You can drive around most handling problems, but being underbraked is much worse, IMHO.
BTW, the 96 brakes are still subject to overheating on a road course. I don't know how hard Watkins Glen is on brakes, I'm guessing it's probably not too bad, but make sure you have _fresh_ brake fluid with a high dry boiling point and good track pads on before taking a SHO to a road course with the 96 brakes. The heavy calipers hold a lot of heat, but if you're careful you can still make them work well at the track.
92sho16
b00sted
Liverpool, NY
Well to be honest with you i think that i will probably fade the brakes out but i like the slicers and dont have the money for 17s so i figured i could just go with the 96 upgrade and i would be better off than using the 10.1 inchers. I will have the bias plugs in by then too so hopefully i will do ok. it is a year from now though so who knows whats in store i could go for a set of the centerline rpm's or excel rims.
PS my dad runs his mustang there at watkins glen and he faded his 13" brembos in a could runs
