Brake Problems--really need help!!
kd7kmp
Springville, UT, USA
I needed to change the front brake pads on my '95 MTX. I purchased new Ford pads, went to put then on and they are too big. They go past the outside edge of the rotor by about 0.125". I then went on to try pads from Checker, Napa, and Autozone. All those pads exhibit the same problem. Thinking that the rotors were the wrong size--perhaps from a non-SHO Taurus--I purchased two new rotors from Checker. They are the same size as what is on there now. Can anyone tell me what I need to do. The current pads will only last another couple weeks. Thanks for the help
Kevin
LaTechSHO
Louisiana
what are the part numbers for everything?
I bet you are being given the 96+ brake pads which fit in the caliper but have a larger sweep over the larger rotor....
ensure you are getting 601 pads (aftermarket) don't know what the ford part number is....
or go back and ask for pads for a 94 sho or a 96-99 NON-SHO taurus
Louis
kd7kmp
LaTechSHO:
Louis
I looked up everything on the internet for a '94 SHO, '95 SHO, and '96 non-SHO. All the part numbers were the same and none had a 601 in them. I finally called Autozone and purchased some Performance Friction pads, #6014. I hope these will work. Thanks for the help.
Kevin
LaTechSHO
Louisiana
kd7kmp:
LaTechSHO:
Louis
Kevin
6014 is a 601 pad.....
what brands are you looking at that don't have that in them?
-- Advance Auto carries this brand among others --
Bendix
MKD601 (titaniumetallic)
-- O'Reilly Auto Carries this brand among others --
Wagner
MX601 (thermoquiet)
ZX601 (quickstop)
-- Autozone & PepBoys carries this brand among others --
Raybestos
RPD601 (raymold - organic)
RPD601M (raymold - semi-metallic)
PGD601 (professional grade - organic)
PGD601M (professional grade - semi-metallic)
-- Bumper to Bumper Auto Parts carries this brand among others --
AC Delco
17D601 (durastop)
to name a few....
Louis
<small>[ September 18, 2003, 05:49 PM: Message edited by: LaTechSHO ]</small>
kd7kmp
I looked at Raybestos from Checker, United Brake pads from Napa, Albany from Autozone and the OEM pads from Ford. I finally looked up the Performance Friction part number and called my local Autozone to see if they had it. They did. I will be trying the PF #6014 tomorrow.
When I called all my local stores (Ford included) I didn't know that I needed a 601 pad. I just took what their computer said. Obviously all the computers are wrong! I really appreciate you help on this thumb . I couldn't have done it without you.
Kevin
LaTechSHO
Louisiana
not a problem....it seems that several companies list the 95 poorly.... from brakes to even APC Clear corner lenses.... they are listed from 95-99
I would imagine that the same is true for raybestos.... and perhaps some others... may have to do with some factory build date or whatever, i don't know... thats why i created the Parts Database... which you can find a link to in my signature.... I'm adding things all the time.... and now that i see you had an issue with this, i will add more brake brands to it so as to cut some confusion
Louis
kd7kmp
Your parts database was the first place I tried. But it wasn't working. Perhaps because of the server move......I just tried it again and it's up now. Thanks again.
Kevin
LaTechSHO
Louisiana
nailed that one on the head..... when we moved the server..... a particular database got left behind by accident... problem solved ;-)
Louis
kd7kmp
Your parts database is a valuble tool. Thanks for letting us all use it. By the way, the Performance Friction pads fit great.
Kevin
