JohnW63
After re-reading the shop manual, I found I was not taking care to get the little tab on the rear brake pads to line up with the slots in the piston. Rotating the piston and properly aligning the slot has helped much of the rear brake noise. I still get some noise but not as often or as bad sounding.
I was going to replace all the pads with AutoZone pads, but I ran into a snag. I got the $6 generic piston tool that looks like a cube and fits on a 3/8 drive shaft. The tool fits, some what but has a tendancy to slip out of the grooves. Is there a better tool ? How much rotating is required to get the piston to retract ? I turned it quite a bit and didn't see much movement at all, if any. Clockwise to retract right ?
JohnW
JohnW
