Brake Pedal Play
Marccus
California
How much distance must be applied to the brake pedal before the brakes really grab the rotor?
I have installed new brake pads (front; the rear are OK) , but I still must depress the pedal almost all the way down before I feel the brakes "grab" and they still feel spongy.
Pretty soon I'll have to pull a Fred Flintstone and put my foot through the floor board to stop. :D
It has been mentioned to me that if all else is OK (brake fluid, rotors, pads), then the master cylinder needs to be replaced. :lol:
I have and '89 with 284,000 mi. and original master cylinder. How do I inspect the Master cylinder to determine if it needs to be replaced?
Is there a "rebuild" kit to bring the Master cylinder back up to spec. :confused:
I intend to do the following right now and this is the first time I've bled brakes:
1. Drain brake fluid from brake reservoir.
2. Remove existing brake lines.
3. Remove existing brake bleeders.
4. Install new Goodridge SS/Teflon brake lines and Russel speed bleeders.
5. Fill reservior with ATE Blue Racing Brake Fluid.
6. Bleed until new brake fluid (blue color) appears.
I don't have 4 jack stands to keep the car suspended with the wheels off. I'm assuming it is better if I can remove all brake lines at once and drain the entire system of old fluid, then install everything and then bleed each brake. But can I do one brake at a time as described above and still be OK?
How long will it take me and could I screw something up so that I won't have any brakes?!! :eek:
I'll just be doing this myself without anyone helping me.
Do I have to do all four brakes, or if I'm short on time can I do just the front first? Will I just up contaminating the system of new brake fluid if I don't do all four at the same time?
Many thanks. :thumb:
poffffd
