Brake pedal after first application
Bill Mc
Hershey, PA
question on my brakes for ya: 91 SHO. When I first hit the brakes, there is the normal feel. When I hit them again about 2 seconds later, it feels like the brakes grab quicker, like the pedal has no travel before the brakes are applied. I don't think it is a vacuum booster issue - the brakes feel like they are power assisted the whole time. I just lose any extra pedal travel, which feels weird. Perhaps the pedal isn't coming back up as far, but I'm not so sure about that. This car had sat for a while and I had bled everything and replaced the rear hoses. It brakes very well in terms of stopping when I need to. thanks for any thoughts.
zak
east of Hartford
I thought the 91's and 92's had master cylinder issues? Never owned either year.
OG-SHOguy
Same as JBeck
Houston, TX
Try changing out the fluid with new in the entire system... i bet either the fluid is old and bad or it has a little air or contaminates in it... either way a fluid flush wont hurt... good luck!
If I understand what you are saying, its normal. When the brakes are released for a while, the pads get pushed away from the rotors a little, so the first application of the brakes takes more pedal travel. If they are reapplied a second time in short order, then the pads have not moved away from the rotors much, so there is less pedal travel to get the same braking force.
OG-SHOguy
Same as JBeck
Houston, TX
Brakes inadvertently work on friction as well, so a cold pedal would feel dramatically different than any pedal after that because of the friction build after the first "cold application" ...I agree, sounds like a normal cold pedal feel.
Bill Mc
Hershey, PA
Thanks guys! Yeah, it feels different than any other car I drive. Like I said, this car sat a while, so I wonder if you guys are right and also the piston is taking longer than normal to retract a bit further. It doesn't feel like the brakes are hanging up or anything. Rock has Morse calipers on clearance.: 4311A....hmmm: http://www.rockauto.com/en/moreinfo.php?pk=2755590&cc=1138665&jsn=10516
I don't think it is related, but I have an ABS code of 26 RH valve body input. The valve body isn't cheap to replace!
