Brake Lights
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Anyone ever have all of their brake lights go out? I fianlly noticed it today. squint The actual lights still work just not the brake lights. It says that the right light is out when really all are. If anyone could tell me how to fix I would appreciate it.
Bizzy
LOUDSHO92:
Check your bulbs and connections. Make sure the bulbs are tight in the sockets. These kinds of problems are really hard to find IMHO.
SHO 17
HOFFMAN ESTATES, IL
check to see if your turn signals work if they don't then your problem is the multifunction switch which costs about $45 and is simple to replace i did mine in about 20 minutes. If the turn signals do work, well then, i don't know what the **** the problem is. When i say that turn signals should work i mean they should flash. If it doesn't work properly then they will just stay on.
LOUDSHO92
Sponsoring Vendor
I havent check the back ones yet but I know the front ones do work. Are you talking about the back ones not working only? Thanks.
SHO 17
HOFFMAN ESTATES, IL
well if it was the switch than both front and back lights wouldn't work but why don't you check or replace the brake light switch. That might be what your problem is.
The multifinction switch does not affect the brake lights. Do you have the LAMP OUT light lit? If so, just replace the bulbs.
