brake help
cyanmauve
Tx
I have a small problem that hopefully ya'll can help me with. I want to buy the Baer 12.5 upgrade and keep my 16 in slicers, but learned today that that's impossible due to the new caliper from Baer. THis is my thought: the old calipers were from C4 Corvettes. If I bought C4 calipers from whoever, and then bought the rest of the stuff from Baer, I could have basically the old 12.5 package that fit under the stock slicer. If anyone could confirm this, give me a caliper part number, or tell me if I'm guessing right, I'd really appreciate it. Also, would any other caliper, like the 96+ mustang cobra work? Finally, does anyone have actual braking distances measured for the 96 upgrade or the Baer 12.5 upgrade? Any help wpuld be appreciated.
shooff-usa
Hi there!
indiana
There are sooo many options,the least expensive ones involve more time and work from your end.
One option is this:
You can get cobra calipers(same as the Baer,made by PBR),have the caliper brackets and rotors modified.This is how Roush made the front brake set-up for the Bondurant SHO's.I have a contact that I got mine from.Contact me and I will ask him can still get them.I did this (got rotors and brackets) from him.Then I got powder coated cobra calipers with pads from www.discbrakesrus.com for$299
BigCaney
N.E. Ky
I am running 12 inch rotors with dual piston PBR calipers and it is a very close fit with stock slicers, but it works.
I first upgraded my '90 SHO to stock '94 brakes and that was a big improvement, but there is no comparision to the braking power that you get with the dual piston calipers and the 12 inch rotors.
I do have pic if you want to see my set up.
Later,
Mike :)
