95-3.2 said:
i dont undertand this shift light. i figure a tach would pull more watts then a light?
If doesn't matter if the tach will pull more current then the light, it's the fact that the tach circuit can't supply enough current for both devices.
You need to run a wire off the cig lighter, or the battery or any other 12 volt device, the radio would probably be good so that the circuit isn't on when the car is off.
Thats what the bottom of a relay looks like. Connect the 12 volt power wire(radio, battery, cig lighter, etc.) into the shift light power. Plug the tach signal wire into 85. Plug the shift light ground/input into 87(this is the new tach signal). Plug a ground wire(connected to the chassis) into 86.
This will make a switched ground circuit. The light will have 12+ going to it all the time and the relay will complete the ground to the shift light, when it reaches a certain voltage.
This assumes you have an RPM switch style shift light. If you have something that uses RPM pills this may not work.
You should try finding the directions for the shift light, it will show you exactly how you need to connect it. It won't show you the correct wire to use though. I'd pull the cluster, and connect it there, see if the tach does the same thing.
The more I think about this, this is not what you need for your application. If you bought a premade shift light, the relay and all should be built in. This setup is really only if you are using a seperate RPM switch and light bulb, which is what my setup uses.
