OK so I had an engine failure and put a new one in, I started tearing down the old one for parts and diagnostics and found something weird...
The rear cam broke all three bolts dropping them down into the timing covers and damaged any pulleys in their path. I went to remove front cam Sprocket and bam, one bolt broken one almost gone and one still intact. I haven't dug into the heads yet cause I'll have to remove the cams to get to the Allen torqued bolts so not sure what's up down there yet.
Has anyone ever had this issue? What should I look for cause this is all kinda new to me. Just trying to figure out why this all happened, when the car died it flashed all of its dash lights and shut down so I coasted to a safe place and stopped the car. I tried to start the car and it tried to turn over once, then the second and third time I tried to start it there was a grinding sound so maybe that caused the damage to the cams? This whole thing is just weird lol :banghd:
