1slickRED89
Guest
after trying narrow gap (.025") and finewire plugs and still having 'blow out' problems, I decided something else was wrong with the car, it sees about 5 PSI of boost.
I set up a bench to test the DIS, coil pack and high voltage wires. this is what I found out. at about 12 KV (~60PSI air pressure) coils 1 and 3 would run out of voltage whereas coil 2 could go up to 25 KV (150 PSI).
I swapped DIS modules with two different 2.3 DP DIS (same as SHO but with 4 coil drivers) same result. tried using a different coil (2.3 DP 2 coil), and BANG, 25 KV. so I think 2 of the three coils are bad, although the resistances are in spec.
will try the same test with a new coil pack (wells?) and see what kind of voltages I can get out of it. I wanted to see 45KV so either my scope is setup wrong or there is another problem.
whats a story without a pic. plugs 6 and 7 are not connected. it may be hard to see but only plug 4 and 8 are firing (coil 2) at this pressure, the other two coils ran out of a55.
pic
pic
