Bolt Size Needed (still)
DougLee25
Hatboro
Does anyone happen to know the bolt size for the battery tray? I lost one last night in the dark while working, and I thought I'd pick another one up on the way home from work. Thanks for your time.
Doug
<small>[ January 06, 2004, 02:44 PM: Message edited by: DougLee25 ]</small>
Bizzy
which bolt? There is the one the holds down the tray to the flat horizontal part of the fender, then there are the 2 that are down near the pulleys that are verticle.
DougLee25
Hatboro
The two that are vertical by the pulleys. I believe all three are the same. Anyone know the size? :D
Edit: The bolts by the pulleys appear to be different but the thread size is to be determined. Any help from the peanut gallery?
Doug
<small>[ January 06, 2004, 05:29 PM: Message edited by: DougLee25 ]</small>
masho95
got Zex?
Chicopee, MA
Actually the ones by the pulleys are horizontal. You're talking about those that go through the tray into the body right? The ones with a 10mm head?
DougLee25
Hatboro
masho95:
Yes, you are correct, the ones by the pulleys actually go horizontal. Is M6x20 the correct size?
Doug
Ishodu
DougLee25:
masho95:
Doug
I would say M6 with a pitch of 1mm and 20mm long.
