bolt and couplers for shift linkage???
ultimatesho
Fort Bragg, NC
dose anyone know where i could get these from or even what their names are?????? someone was out digging for tools around my car and now the bolt and couplers are gone........
Storm-Chaser
Shit Louis
Did you find the bolts/linkage yet?
Are you talking about the long 19mm bolt that goes into the transmission boss (shifter linkage, gear shift control), and the 3-piece bracket assembly that holds on the shifter rod?
Storm-Chaser
Shit Louis
I believe he's talking about the bolt and linkage coupler at the transmission mount (front), not at the shifter linkage under the shifter boot (rear).
ultimatesho
Fort Bragg, NC
yes i was talking about the ones that connect the shifter to the tranny....i ended up getting a cheap bolt with somewashers and nuts.......works for now but if someone has these i would gladlly take em off your hands......
Storm-Chaser
Shit Louis
Post in the WTB section. Given all the blown transmissions over time here, both should be easy finds. Also, bizzy should have these.
If not, let me know and I can direct you to a few others who should. I'll probably be able to get them for you (NOS) if it comes to that.
Btw, bizzy calls that little three-piece connector for the shifter rod the "Tie-Fighter bracket" :rofl:
