tery
Silvia survived the purge- summer car
I am really happy to find out that it is NOT the cam chains making that random clacking noise, thanks to the stethoscope, it is for sure something down in the tranny or clutch set up. That's not the greatest news but I wasn't ready to get into the cam chains stuff just yet. Someday I'll have to I suppose, but for now. more diagnosis is called for to determine if it is a clutch issue of "gear rollover, as suggested as a possibility. Anyway. Here's a couple vids of Bob running. The motor sounds very good and you don't hear the random clack until you get into the driver's side wheel well. Also with the steth, I can hear the random noise a bit on the clutch arm and more on the tranny housing. If anyone can tell me how to do more "looking" to see if I can nail down just what it is, that of course would be greatly appreciated.
This is the engine that has the 9lb flywheel and although it got better with the clutch pedal adjusted all the way up..(self adjuster had slipped and wasn't pulling clutch apart fully)...it will still pop out of 1st gear if you try to ease the clutch out. If you just drop it. like pop the clutch, is doesn't pop out of first and/or if you give it a 3-3.5k rev before you pop the clutch it does just fine, but again, if you try to slip it out at low rpm, it pops pretty violently out of first gear. No problems at all with the other gears although sometimes it feels like it doesn't wanna go into third without some parallel shifting..like down to four and then back up to three, rather than two to three. Does this sound like a throwout bearing issue maybe...And would that have a random clack noise if it was bad or damaged??
tks in advance.
T
tks in advance.
T
