I dropped a '15 motor in my '11, so they are compatible. I believe the cutoff was for the '13 MY when they went to composite valve covers and different sensors. The '10-12 motors are unicorns so I doubt you'll get one of those, but if you do, you'll need to run the aluminum front valve cover and the '10-12 PCV intake tube. There's an extra boss on the later head for the composite valve cover mounting bolt but not on the earlier head. HPFP and its mounting location was identical on both motors. Other than that it's cam sensors, crank sensor and flex plate that would need to be swapped. You'll probably end up with a 13+ motor in which case you should be able to just drop it in and run it, plug and play. Might be a good idea to check over the flex plate and sensors just to be sure though.
On a side note, with how unfrequent lockdown travel was, I was worried about octane level dropping because the fuel is sitting in the tank for weeks. I removed the tune as a precautionary measure to avoid spark knock. Stock tune should do better with aging gas.
