blower motor control module
betterman
canada
does anyone know where I can get a blower control module from other than ford. Also, anyone who has bought one, how much did it cost.
Used from ebay and http://www.alfitz.com You may want to address why it failed. Usually there is water leaking on it and I would guess if that's the reason for failure then another might not last too long either. Not 100% but worth checking out.
betterman
canada
I've had the module out once and it looks as though its not working to corrosion caused by humidity, I took some electrical cleaner and cleaned off the circuit board and it worked for a while but then it went back to blowing full out. I don't think water was dripping on it.
