revhardSHO
No matter what mode I put the EATC in, it always stays in "defrost"
My eyes are constently getting blasted by hot air, and they cant take much more.
I have checked a couple of the vacuum lines near the cruize control module, where else should I check? They all look good, I replaced most of them a couple years back.
Also, when I shut the car off with the blower on, I hear something like a peice of plastic "drop" or fall into place. Sounds like its coming from the blower area. Would this be my blend door? How hard is it to get at? What would be causing this?
The climate control is a hardbutton unit out of a 95 and is in like new condition, and everything is attached correctly in the back, no vacuum leaks there. Has been working fine for the last 6 months.
I have done some searching, but I have not found exactly my problem.
Any tips, advice is appreciated.
