Blower control mod. replacement
shofun93
Rootstown, Ohio
Has anyone replaced the BCM? 93 ATX and the blower will not turn off. I have read the other posts and think this is the problem. Where is it and how do I replace it. Thanks all
I just located the BCM thanks to all of your great posts. It looks like a small black unit with some wires and two 1/2" round openings, one of which has a corrugated plastic hose connected to it. Does this sound like the part? Shouls hoses be connected to both openings? Thanks for all the help.
Slo-Sho
It wasn't me!
Crossroads, CNY
Yes, that is the part. Yes, both hoses should be connected. IIRC you can use an 8mm nut driver to remove the two screws.
shofun93
Rootstown, Ohio
could there be two BCM's? I see the one mounted closer to the glove box with two connections and then there is one a little further back and to the lower left with one connection going to the front BCM. WTF??? The one in the front has one tube that goes up into the dash and the other hose goes to the unit further back. The one in the back actually has a white sticker on it that says "variable speed blower control module" and some other crap, it has two hose ports one is hooked to the first BCM and other is not connected to anything. PLEASE HELP ME!!!!
Thanks all
