carterh
I have tried searching, so please **** off if that is what you plan on saying
I recently purchased a new head unit for my car and am now running into issues over the installation options...
The output from the deck is 50W (RMS) per channel, which is without a doubt lower than the output of the stock amp. This leaves me now with three options. For option one I could run everything as stock from the head unit back. With option two I can just run the speaker wires straight from the deck to the speaker similar to what you would find in a regular SLO set up. For option three I can run my RCAs back to a new amp in the trunk and use the existing lines running to the speakers.
Option one is pure silliness. Why on earth would someone try that?!
Option two seems to be okay, but then I have to rewire the speakers, and this also means that while I am in the door messing around I would likely replace the speakers in exchange for something of high fidelity. This seems expensive.
Option three seems even more expensive considering I would have to run RCAs, buy an amp, and buy higher wattage speakers.
What have you done? What would you recommend? How are the stock speakers when run off a high power head unit? I am a stickler for fidelity- sure Sony Xplods are loud, but what is the point when they sound so terrible?!
Cheers,
carter
Cheers,
carter
