Blend Door Problem
k_mesaros
Roy, Washington
My EATC does not work. I got the self-test to work, after randomly hitting the 3 buttons that are supposed to initiate it, and got a code 2. My problem is that the blower never comes on. I can swap it between floor, vent, defrost and I hear something going on, but the fan never kicks on. When I put it on a manual setting and mess with the + - wheel I can hear a module clicking, but the thing never blows air. WTF would the blend door have to do with this?
Kevin
rangerj
Brunswick, Ohio
Test the blower motor and its wires. Is it getting voltage? If not, look for a wire, switch, blower speed controller, or connection problem. If it is getting batery voltage and will not run try applying battery voltage to the motor connection. If it will not run the motor is bad. rangerj
