Bleeder Screw Sizes
Dassin
Teh Silver Bullet!
Poulsbo, WA
I ordered myself 4 Speed Bleeder replacement brake bleeder screws from RaceShopper.com, after checking out which ones I "needed" from speedbleeder.com. The page indicates that the front and rear on ALL TAURUSES with ALL BRAKES is their "SB1010S" size.
They work great! On the rear.
The front screws seem different. Instead of having 11mm (if I remember right) heads on the rear, for example, it was between 9 and 10mm (3/8 or some crap?) on the front. The diameters of the actual screws were different also, so it was kinda lame.
Any insight as to which ones I should get?
Thanks!
NJSHO
Clean Your Shorts!
NJ
I got knock off speed bleeders and Im pretty sure they were M10. They worked on the front and the back even with having the 96 upgrade on the front. Ill see if i can find the packages around to check.
Dassin
Teh Silver Bullet!
Poulsbo, WA
If I were to use the same sizes I have on the back, on the front, I would definately be forcing it in. Maybe the 96 upgrade has the same size, but it seems like the <=92 knuckles are different.
