Blazer foglights in!!!!!!
1992blackmtx
cleveland,ohio
just got my blazer fog lights and put them in, they are way brighter than the stock ones, and install was fairly simple. here are some pics.
CTOESHO
DeKalb, IL, USA
Wow, those look amazing. How bad was the install? Did you have to soder anything together, or was it just plug and play. Are those the bulbs that came with the blazers, or did you have to supply your own bulb. Thanks.
1992blackmtx
cleveland,ohio
i actually just removed all the fog lighting brackets and screwed the new bracket that came with the light to the plastic support that the old brackets were mounted on, you have to cut the factory wiring and splice it in with the new wiring. those are the blubs that come with the lamps, no bad for only $20.
jcostantino
Coral Springs, FL
You shouldn't have to change the factory wiring.. I took the new bulbs and put them in the OE sockets.. works fine so far..
Anyone tried different bulbs in the $20 Blazer fog lights? I'm tempted to try but they might melt.. The factory ones I had cracked from the factory lights' heat but the Blazers have metal shields inside to reflect the light back and maybe to protect them from the heat.
Jeff
