I consider myself a big car audio ******. Along with the title, comes the need/want for a great sounding stereo system. I already have installed a Pioneer DEH-P6800MP head-unit in the SHO, and have a 800-900 watt (continuous/rms) 4-channel amp on the way for my Christmas present. I will be running my front-stage components off of about 200wrms each side on the front two channels. The rear channels will be bridged, sending a subwoofer about 400-450wrms. I basically have everything all planned out, yet still sketchy on a couple parts. One of these parts being the alternator, and the "Big 3" upgrade.
I'm not sure if many of you are into the car audio thing, or know what the "Big 3" is. The "Big 3" is the replacement of the following wires:
1) Alternator positive to battery positive(w/ a fuse)
2) Battery negative to chassis
3) Chassis ground to engine block ground
First, I'm wondering if anybody else here has done this. I know that the alternator is a bitch to replace, you have to drop the subframe and everything..... Would this be a problem when replacing these three cables? Also, would anybody be able to tell me where each cable is? Thanks in advance.
Beck
Beck
