Terrorizer
SHO or ****
*edit- I am talking about the intake ports that lead into the combustion chamber that are visible when the intake manifold is removed*
I am in the proces of doing my 60k and have the manifold pulled off. There is TONS of gunk in there. I can scrape it out with my finger. I've gotten the big stuff out by using a rag and my fingers. I also used some carb cleaner like the SHO phoenix write up suggested. Does anyone know any other methods to help get that junk out? Also, Should I be concerned at all that after spraying the carb cleaner all of the shit caked on in there has just settled on the bottom of the port and is going to get sucked into the engine? Also, I think I may have pushed some of the junk into the fuel injector while i was scraping my fingers up the side, will the fuel pressure push it out of the way? Ill try to wipe it off the best I can.
