Best way to raise line pressure...
MilTownSHO
Horicon, WI
Considering NOS for the 97, what's the best way to raise line pressure for the tranmission so it could handle a 75-100 shot? It is currently out of the car so now is the time to do it. A Trans-GO shift modifier and a B&M trans cooler are going in already.
Would the FPS chip do the same thing and be easier than doing it through the transmission? That way if I didn't like it I could just pull the chip and get it changed I guess...
I just don't want to burn up a new trans... :bonk:
Where's Kirk when I need him?! :cool:
Axianator
I am a banana!
Roanoke, TX
IMO, a properly-programmed chip is the only (proper) way to go for raising line pressure.
As for your tranny rebuild, I'd leave the line-pressure-increasing valve body mods from the TransGo out of the loop and let the EEC handle all of your line pressure modifications needs via a chip. It's much easier to start soft and work firmer (via a chip) than it is the other way around. ;)
Shoman594
Moderator
Lockport, IL
If you dont mind me asking how much was the tranny rebuild with the shift kit ? Tring to get a ball park figure. :bonk:
