Best Strut/Spring Package?
S
shoebilly
Guest
Has anyone rate tested the cut versions of the basic spring brands, moog, eibach, ect... including oem? I went to coilovers on one sho and you can pick the rate but not without conversion hassles/expenses.
ManySHOs
South Jersey
Swapping coilover springs isn't that big of a deal. How else would you change the spring rates? :)
Ian
S
shoebilly
Guest
Ian
I can get a (my choice) coilovers for $60 now. That car...I talking about what gives with cutting the different brand springs and how much they make a dfference. I can cut 100000mi stock springs now if I want, but what will be the end result if I did this. I don't even want to know. After all they have aready sagged. The old stock springs in my opinion are all shot and would never consider using them again. I am curious about the other brands cut for lowering porposes.
zach44102
BIG TURBO
Georgia
i need to compare two diifferent set ups. both use sensa tracs but which springs and whats the pros and cons to each setup. intrax or cut moogs? looking for 1 3/4 in front 1/2 in back
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Sorry had too:
Resurrection
You have been answered a few times and now you are changing your question.
The Moogs will probably raise the rear as you are sagging. You can only get a round a 1/2" drop with cutting. With Intrax you get stiffer springs and 1.5" drop.
shonuffmine
wildchild
sweating balls in fla.pan
Its the never ending what spring -strut should i get question? freeking cut moogs cc if ya want a decent ride or intrax if ya wanna beat your nuts off and just so you ya can be pimpin like thats really important,go over to tccoa and ask this freekin question cause the tards over there are worried more about looks than function! Calling Babs, the leash is off have some fun buddy
zach44102
BIG TURBO
Georgia
omg i just wanna know if intrax and monroes are compatible with each other and if any one has used this combination.
SHOtimer
#2910
Santa Clarita, Ca
...then ask the question, don't revive a 4 year old thread.
You could just search the answers are there.
By compatible - yes, you can install monroes on intrax springs.
The monroes will probably die shorty, but they have a lifetime warranty...so you can just keep exchanging them (that's what Continental sho does, IIRC).
Doug
Rubix
What ^ he said.
This question of your's has already been answered in one of your other threads...
http://www.shoforum.com/showpost.php?p=1131905&postcount=3
http://www.shoforum.com/showpost.php?p=1131928&postcount=5
http://www.shoforum.com/showpost.php?p=1132030&postcount=20
Those were responses to monroe + intrax. ****, have you looked on shosource.com? The website will tell you it's not recommended, but they are "compatible" and will work if that's what you want to do.
zach44102
BIG TURBO
Georgia
ok thankyou. i searched it and didnt find anything about monres and intrax and this was the closest thing i could find. i didnent just ask the question because i knew i would get flamed
