I like the stock setup. Draws air from the hole at the fender and easy to change the element. Most of the other set ups have the filter drawing air from under the hood where it's significantly hotter or sticking out or at the stock fender hole.
The old sho shop can intake looked great, but I don't know if it performed any better than other setups. You can change the filter element and use a different elbow here or there, but I don't think the difference is worth messing with unless you have a higher flow issue with something like forced induction.
