sperold
Last to Know
I am interested in what is the best approach to re-do the brake lines on a SHO with ABS.
I may get the stainless line kit and replace all lines to be sure of long term reliability.
This will be farmed-out, so I would like to know the best approach, as the shop is not above taking advice from a customer.
Is there an advantage to taking out the master cylinder and booster apparatus to get a better shot at the ABS cluster of lines?
Is it better to remove the ABS unit and motor from the frame mount and plumb some of the lines away from the car.
Is this an up-top or down-below exercise. for the lines in the engine compartment?
Any tricks or things to avoid?
Any advice on the rear device that routes the lines to the 2 rear brakes (the thing with the spring on it).
