SHOkid13
Take it to the track
I finally got my trans apart, and I have a few things I want to run over...
Everything looks great except for a few small things:
5th synchro and gear are showing a fair amount of wear, while the blocking ring is almost untouched. Weird… Has anyone seen that before? You can view the pictures here: http://home.earthlink.net/~shokid13/id11.html (Can't figure out how to post pics here yet...) The inside of the blocking ring is perfect, no wear at all. When I put the gear on the blocking ring and the synchro, the gear spins freely... Is that normal? All of the other gears lock up under their own weight.
I want to replace the input shaft bearings due to some minor wear patterns. Based on what I have read, these are hard to get. So, I did a little searching around and found some that seem to be the same thing. I found the front bearing/race (LM67048/LM67010) for $5.95/$3.55. Also, for the rear bearing/race (LM48548/LM48510) for $4.95/$2.75. Maybe I am missing something here… if so, please let me know. I found these at: www.etrailer.com. Just use the search function on the left hand side to find the bearings. Both seem to be a fairly common bearing in wheel hubs...
Like I said, everything else is perfect, so I guess I got a good one!
Thanks for your help!
Matt
Matt
