done correctly as opposed to what ? cause turning SBB's in BBB's Is quite hard to muck up. even if you overbored them they would still function properly.
only set i have ever seen done wrong were bored out but then stock plates were reinstalled.
who is nanotoxin55? are those bbb's done correctly?
opening the housings up a bit to far and running the proper oversize plates: you would never notice a difference compared to "done correctly"
opening the housings up and sticking stock plates back in ... eeeh, might loose a few ft/lb down real low, but its such a hack way to go about it. all that time / effort and to do it right would only cost an extra $20
It's 1993MTXSHO on the forum. Met him personally a bunch of times, I think those are the BBB's he's had on his car for a long time.
