Battery!!!
9
94ShoATX
Guest
OK...........Well I have a car called a Taurus SHO, I dont know why I drive it!!!YOu know what that is??Well anyways the battery likes to go dead on me. I got a new battery and new alternator..So It keeps going dead.WHY!!!All the lights on the interior starts shutting off and battery light and ever light comes on.
DavidBGano
Monroe, MI, USA
You've either got an electrical leak... like for an alarm, remote start, etc... or your wiring to the battery is corroded and not letting the juice get through.
Are you sure the battery is dead? Did you test it to make sure there was no current?
I know from personal experience that the positive lead can corrode and not the let the car start... but if you f*ck with the wire enough, it will usually fire... until you can replace the bad wire.
Good luck, fellow Monroevian.
David Gano
94 SHO ATX
1000 watts Kicker Amps
2 10" Kicker Solobarics
JL XR Component Speakers
Clarion Head & DSP Unit
Fine89
Pottstown, PA
There's a test procedure in the Helms. You have to pull the battery cable and hook a light in series with it...you can use a taillight bulb. If it lights, something is drawing current.
While it's lit, pull the fuses one at a time and see if it goes out. If it does, it something in that fuse circuit
NOTE: I tried this on my friends mustang but pulling fuses didn't do it. He finally found it was an intermittant switch on the glove box (parked in the dark and saw the light on!!) Sortof like that refrigerator light thing! Good Luck
