battery light problems
tavius
arizona
i am getting a battery when i put the key in. the car will start up fine but the alt is not putting out. this is the 4th alt in 5 months, I had the alt checked at autozone and it turned out to be fine, I have also replaced the alt connector, i got the connector from ford , but it has 3 wires instead of 2. so the middle wire i did not use. I even replaced the battery just because it was old anyways. What could be causing this? Is there a way to hook up the alt directly to the battery, that way i can verfiy if it is a bad ground or something.
Please help the car has been sitting for months because of this problem!
S-H-O-Man
Rincon, GA
FWIW I have had bad experiences with AutoZone, PepBoys alternators in the past. Try a NAPA or Ford reman one.
tavius
arizona
i bought the alt at Napa but took it to autozone for testing. And to different people told me it was good.
The alternator is grounded through the case. Make sure the MEGA fuse is in good shape and it is tight on the mount.
