Battery LIght On, Help?
Nook
SLC
Hi there,
My battery light is slightly on, only visible at night, about 1/4 the way on.. any thoughts? Runs fine.
NorthernSHO
Ontario, Canada
My battery light has been coming on every once in a while since February and my car is still running. But I agree your altenator or battery is most likely on the way out. Just take it to a shop and get them to see how your system is charging before you replace items. This way you aren't replacing things that don't need replacing.
naval-avi8or
Chesapeake, VA
NorthernSHO:
I would highly suggest you get your's replaced as well. You will spend much more in repairs if the constant load transfer from alt to batt ends up causing a major electrical malfunction.
