After much debate, and hearing a lot of naysaying I decided to take on the separation of heater controls/radio to install an aftermarket cd player in the dash, long story short, I've got it done, my problem now is that for sometime I've had a battery drain (even before starting on this project), I took it to mechanic, he says the drain is on fuse 24 (under the dash), goes on to say that the keyless entry module is causing a pulse drain, and something else is causing a steady drain (he can't diagnose other drain because he says my fusebox is wired differently than his schematics). So of course he's saying it's the heater controls/radio project is causing the issue, I ask if we could put a toggle switch in to **** the circuit when car is shut off (wouldn't that prevent the battery from being drained??). When I took it to him the battery would be dead in less the 48 hours, so it must be a substantial drain?? This is only a 5 amp fuse, can anybody give some advice/shed some light on this connundrum??
