Battery cable terminals
EMB2580
Mike is a L O S E R
Zion, Il
Where could I find a set of terminals for theese monsterously huge cables on this thing? Mine still has the original ones and they both are in bad shape, the negitive has acually started to crack/break. Any idea who sells ones big enough?
95azSHO
phx,az
Welcome to the club if you want to go cheap Autozone has some for about $12 each. Napa about $33 each. Autozone also sells an Accel Batt kit for relocation to the trunk for about $50. With this you can make your own. Hope this helped.
EMB2580
Mike is a L O S E R
Zion, Il
Thanks for the tip. I figured AZ or Napa might have something I could use. I've also know about people moving the battery to the trunk, something about in it's original location, there very poor ventilation or something?
wood_e
The dude
Ames, IA
You can buy new terminals they're inexpensive and you can crimp the new ones. When I had the SHo I did it for under $20. I then relocated the battery later with a summit kit.
ecoastkid
PA
I just removed both of the cables and brought them to the parts store. There I got new cables of the correct length for just under 20 bucks...I think for the price, its not worth putting on just terminals. The job takes maybe an hour tops
EMB2580
Mike is a L O S E R
Zion, Il
Cool, so is that $20 a piece or $20 total? Also, I know the + cable goes to the relay on the fender, and the - cable goes to the block...right?
95azSHO
phx,az
On mine its just to the drivers side of the starter. Just replaced it last night, took awhile its a bear getting the old cables out. I went the cheap way $23 total at AZ got the 48" and the 56" zip tied all set.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Dont buy the SHO kit they sell in auto parts , just take a generic batt terminal , one size fits all (cept General Mistake)
ecoastkid
PA
less then 20 for both...(7 something and 9 something plus tax...)
They have quite an assorment. I found a negative with a 2nd smaller quage wire attached with a butt connector already on it about 6 inches away from the end. It was perfect. I got the same setup on the positive side so I can add an accessory later...
Redskull
Badass Mo'fo
New Haven, CT
I've found more often than not that the crimp-on's are nothing but junk. The connections are poor to begin with, and after the smallest bit of corrosion sets up, the huge voltage drops will give you electrical nightmares. Battery cables are never something to cheap on, considering it's the one thing whose failure will **** *everything* in the car, all at once.
95azSHO
phx,az
I agree the crimp-ons are junk. AZ does sell a good cheap alternative which is the one piece 2 gauge cables for about $12 a piece. Expensive doesn't mean best.
