ball joint & spring replacement
sho_u
port vue, pa
hi all,
i need to replace my pass side control arm/ball joint and coil springs.
is there any one with "DIY" tips???
which one should be done/taken apart first.
also what tools are needed??
thanks
bryan
masho95
got Zex?
Chicopee, MA
sho_u:
hi all,
thanks
bryan
I would start with the control arm/ball joint. Remove the tire, tie rod end from the knuckle, and sway bar end link. Take out the control arm to knuckle pinch bolt and nut. And then pry out the ball joint from the knuckle. Remove the tension strut nut and the control arm bolt and nut at the subframe. Once that's all out you can slightly pry the control arm out from it's seat in the subframe. Then try to slide to control arm off the tension strut and the new one will be ready to go in. For changing the spring you'll need to take off the strut to knuckle pinch bolt. Then the knuckle should slide down off the strut/spring assembly. Remove the upper three nuts on the strut tower of the whole assembly will come out from below. You'll need a spring compressor to remove the spring from the strut/spring assembly. Once the spring is compressed remove the upper middle nut and it'll come all apart. I'm sure I might have missed a couple of things, but this was the best I could do from the top of my head. :) But the most important tool you're going to need for changing the spring is the spring compressor. Good luck with your work.
sho_u
port vue, pa
thanks for the input.
sounds like i may be able to tackle this one!!!
then its time for burnout
<small>[ March 27, 2004, 12:51 PM: Message edited by: sho_u ]</small>
masho95
got Zex?
Chicopee, MA
On a side note I found 2 broken springs on my 95 when I switched them out for the Tokico/Eibach setup at about 85K-90K miles. One in the front and one in the rear of the car. The springs broke right at the bottom of the spring nearest to the knuckle.
Broken spring
NetNinja
Hotlanta,GA, USA
wow, that's not good.
Thanks for posting the picture! A picture is worth a thousand SHO's wink
<small>[ March 27, 2004, 11:39 PM: Message edited by: NetNinja ]</small>
sho_u
port vue, pa
thats exactly where mine broke!!
pass side bottom of the spring ( barely hangin on )
i wonder if thats why the ball joint is startin to go bad???
