Ball bearings
rktmn
Well-Known Member
miami
I have a rumble comming out from the left front axle. It feels like damaged ball bearings. I lifted the front end, and there is a bit of play when I shake the wheel.
Do I need to replace the axle, or is there a set of ball bearings that are damaged?
Jose
rktmn
Well-Known Member
miami
So I need to pull the axle out also to replace the bearings?
Irish Pride
Irish Inside
MusicCityUSA
You should create something really cool out of aluminum to completely replace the bearings. I've got the same problem and will be first in line. LOL
pjtoledo
'ol man in the SHO
toledo,ohio,usa
that transparent aluminum that Scotty alluded to should be on the market any day now, I hear it's a great bearing material
