89625
TAURUS/SABLE CAMBER ADJ PLATE
Now you can bring the front camber on Ford Taurus and Mercury Sable Sedans or Wagons back into specification. This kit will provide up to 1-1/4 degrees additional positive camber to stop inner tire wear. Designed to be installed with no cutting or grinding. To install, simply remove the entire strut assembly, compress the spring and replace the O.E. upper strut bearing plate with #89625. This O.E. style adjuster is adjustable after installation simply by installing a different cam washer. One kit covers one side of the vehicle.
Estimated Installation Time - 1.0 hr/side
APPLICATIONS:
Ford: 1986-95 Taurus,
Mercury: 1986-95 Sable.
NOTE: Adapter spacer #89645 may be needed.
89645
SPACER PLATE KIT
This versatile adapter plate can be used together with our #89625 camber kit to provide a camber adjustment on the Ford Windstar, or as a spacer plate to resolve the "squeaking" noise associated with the Ford Taurus and Mercury Sable outlined in Ford TSB 93-14-11. Installation instructions for both uses are included.
Estimated Installation Time - .2 hr/side as a spacer plate.
Estimated Installation Time - 1.2 hr/side as an adapter plate.
APPLICATIONS:
Ford: Up to March 1993 Taurus Sedans & Station wagons (as a spacer plate), 1995 & up Windstar with the #89625 camber kit (as an adapter plate).
http://www.specprod.com/NEW_DIR/NEW_INTRO.HTML89645
Taurus/Sable Front Camber Kit (Pair)
This kit provides front camber adjustment on popular late model Ford Taurus and Mercury Sable sedans. Camber adjustment of up to 1.25º. These plates are sold in pairs, one for each side of the vehicle.
Estimated Installation Time - 1.0 hr/side as a spacer plate.
APPLICATIONS:
Ford: 1996 & up Taurus Sedan
Mercury: 1996 & up Sable Sedan
<small>[ March 25, 2002, 09:39 PM: Message edited by: 89 Gary ]</small>
